Aluminum Heads A.R.P. Bolts
I was told by a local mechanic to go by ARP's specs when torquing down my heads with ARP bolts. I want to put my heads on today though because I work during the week but ARP's office is closed on weekends. Do any of you know the specs I should use for this?
RE: Aluminum Heads A.R.P. Bolts
Damn guys it seems like this should be easy info. to obtain. I've searched the net and this forum for torquing procedure and specs but all I can find is info on stock applications. I have Canfield heads, Fel-Pro gaskets and A.R.P. bolts. HELP PLEASE
i really have no experience with those heads, so this might not be right, but generally speaking, most heads are torqued between 65-95 ft lbs, depending on the application. small 4cyls are around 65, and big block chevy's and **** usually get around 90, so maybe 75-80 would be good in your case
ORIGINAL: mattdel
generally you torque the head down to the heads spec, not the bolts. the bolts can handle it.
Contact ARP and they can tell you the specs.
