best H/C/I setup 4 me
RE: best H/C/I setup 4 me
tfs,afrs,edelbrock all are good.try a proven set up combo. i had afrs there good..but for $ i had a edelbrock rpm ported and flow more avg air now...edelbrock rpm set up is freat..the rpm2 intake for efi is proven over the others by several magazines...were tqalkin about avg air flow,not peak,peak isnt what ya want its more avg.. edelbrocks specs are like 492/520 and 280 adv ..no 2 motors will post same#s tho usually.. even if usesame set up/// good luck
ORIGINAL: ih8chevy
yea its a waste for p and p of the stock heads, the afrs are expensive and can be found at most major parts store like summit or jegs, and they run at around 1200-1400 depending upon which u get
theres a good set up right there. but i like the afr's more than the trickflow but the intake and cam are very nice products
ORIGINAL: xtremestang94gt
twisted wedge with spring upgrade, anderson n41 can and holley systemax
tfs stage 1, afr's or tfs heads, trickflow or RPM intake.....Supporting mods like bigger TB and MAF too...You should get some really good power with all that. Upgrade to 24#ers and 190lph fuel pump w/ adj. fuel pres. reg. and with a good tune you'll be set.....
jwog666
12-27-2021 08:09 PM
