Update
Ok the boggging problem im having after 2000rpms is getting a little better....i cleaned all components and put seafoam in crankcase, gas, and brake booster( smoked alot)...however it is still doing it. do you think it could be bad gas? car sat for a little but not like two years or anything. I also replaced the fuel filter. thx for any input
RE: Update
It could be bad gas maybe drain it out, but I would try this first.... Techron : cleans fuel injectors intake valves and combustion chambers you can buy this at autozone....Good Luck!!
RE: Update
Thanks but i headr seafoam works a lot better...
RE: Update
If the bogging is getting better, you may just have to keep driving it and running Seafoam through the fuel system. It's not good for a motor to sit, as fuel in small orifices turns to varnish faster than you'd think. I used to have to clean/rebuild carbs on bikes that had only been sitting for a couple of months. Given, carbs are different from EFI, but varnish is varnish.
All this assuming that you don't have any botched mods done to your car. |
RE: Update
Opps...wrong thread.
