ain't fast with out suspension?
k i am building up this pretty crazy 351 windsor that i'll be running high 11s on the shot.....but i have nothin done to the suspension its all the 4 cyl stuff......i have sticky tires but with out control arms and drag springs we i be spinning all the way down the track?
RE: ain't fast with out suspension?
ORIGINAL: primetime5.0
crazy windsor that does 11's on nitrous? doesnt sound crazy to me..
Theres another fella on here with a mostly stock motor and huge suspension upgrades and hit 11.5 with spray....
i'm telling you man..you are gonna need alot more work then just put in the 351 and run it.. you cant use your stock fuel pump cause it is way too much pressure for a carb.. your gonna want more then a 600cfm carb and performer intake if you are using those roush heads.. your gonna want more then the stock cam too.. your also gonna have to get a posi rear end cause a 1 legger isnt gonna cut it for drag.
