how do i find out if my stang is posi
#21
RE: how do i find out if my stang is posi
ORIGINAL: 88BlueGT
If you have the stock rear than its an 8.8. It should be tagged anyway.
Also, you CAN buy a new rear but I wouldnt. You can get a used rear with gears already installed for 1/4 of the price it would cost for you to buy the rear and put it in.
#22
okay if the car is in neutral both tires spin the same direction when in the air
in gear they spin opposite
car lays 2 rubber lines about 30 feet long (only time i ever looked at my own marks)
last time i tried doing a donut i cut the wheel all the way to the left and with no brake i just sat there spinning at like 6500k until finally it started to go...???
tire wear is identical.
#24
read the tag and call local ford dealer thats what i did, also just get the gears from jegs er sumthing and take em to trans place they usualy do ring and pinion swaps.
