atdc its 93 octane right?Timing lights??
who makes a good but cheap timing light? set at 14 degrees after tdc its 93 octane right? does the car run more efficiently this way anyways? thanks
RE: atdc its 93 octane right?Timing lights??
afraid you've got it backwards there stangtangGT! you set the timing BEFORE tdc, not after. 14 degrees will probably need at least 93 octane to prevent detonation. Sears.
bond007
08-26-2015 11:36 PM
