75-300 shot needed
RE: 75-300 shot needed
ORIGINAL: drhoward
only a 300 shot? why not a 20000000 shot, I think mustangs can take it
try the message boards here or on corral people are always selling them for cheap but you might want to do some research first, the more you know the safer your setup will be
Kev
Kev
I have an NX SHO Wet kit and have been spraying a 250 shot for 5 months with no problems.
Bottom end:
Stock Block
Stock Balanced Crank
Stock Balanced Rods w/ ARP Wave-Loc Bolts And Removed Stress Risers
Speed-Pro Forged 11.5.1 Pistons
Cometics Head Gaskets
Thinking about spraying a 300 shot soon
Bottom end:
Stock Block
ORIGINAL: threeg502
Hey I'd like to try out a 20 million shot. Finding a 10000 pound bottle could be tough!
ORIGINAL: drhoward
Kev
Kev
ORIGINAL: WLingle92lx
Bottom end:
Stock Block
Bottom end:
Stock Block
it doesnt matter if its a wet kit. I have a wet kit also. When you spray that much with just a 255 lph in tank pump, your drawing too much fuel away from your fuel rails and robbing your injectors of fuel. You are most likely runnning lean as HELL. I have 255lph in-tank pump with 24 lb injectors, and I will not spray more than 150, if you want to be safe, I would suggest the same. Theres only soo much fuel you can get with a 255 pump on 24 lb injectors. I would suggest 30lb injectors(at least) with a fuel system of some sort. I plan on using the Aeromotive Competition Kit. Its got a killer fuel pump, the A1000, with larger lines so itll support a 300 shot. You should definatly NOT spray 300 at it with just a 255lph in tank pump and 24 lb injectors.
