cruise control not working
Old 11-16-2006, 05:54 PM
telsonman
telsonman's Avatar
Default cruise control not working
ok, i got an 87 gt. my cruise control hasn't worked since i got it. i've never been able to figure out why. some dude told me that it could be the "speedo" or something under the fender side. i'm clueless. anyone have any ideas on how to fix this???
thanks,
jeff
telsonman is offline
Old 11-16-2006, 06:09 PM
88BlueGT
88BlueGT's Avatar
Default RE: cruise control not working
Not sure about the speedo stuff but your cruise control stuff is all inside the fender on your driver side... I think
88BlueGT is offline
Old 11-16-2006, 06:40 PM
dillon1340
dillon1340's Avatar
first thing is to check codes. make sure the speed sensor is not throwing a code...then check linkage, both to the throttle and the vacuum to the inner fenderwell. after that pull the plastic inner fenderwell off and look at the speed control motor. sometimes the nipples (lol, i said nipples) break off and it's just a matter of supergluing them back on. mine was broken off from someone probably hitting the fender at some point...you can also check the wiring in the steering wheel and the fuse.
dillon1340 is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
iculookin
09-02-2015 12:34 PM
09-01-2015 08:16 PM
defarmer
08-13-2015 06:40 AM
Quick Reply: cruise control not working
