MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   5.0L (1979-1995) Mustang (https://mustangforums.com/forum/5-0l-1979-1995-mustang-14/)
-   -   runs bad, but only in the rain?? (https://mustangforums.com/forum/5-0l-1979-1995-mustang/206710-runs-bad-but-only-in-the-rain.html)
GeraldineRyder 11-16-2006 11:43 PM
This week my car started runnin bad, but then it got better then bad then better, it is really pissing me off but the only thing i have realized is its flooding out but only when it rains. Can some one tell my why or at least where to start looking for a reason that its dooin this? and by the way its a 94 gt 5spd basically stock.
Ninety5five0 11-16-2006 11:45 PM
RE: runs bad, but only in the rain??
YOu got a fender mount CAI ?
nitrous_bob 11-16-2006 11:46 PM
cracked dizzy cap ? broken spark plug wire ?
my guess is spark for sure.
PRO50SC 11-16-2006 11:46 PM
How old are the ignition parts. Take a spray bottle full of water, next time the weather is good, start the car and spray down the secondary ignitioin parts and see what happens.
ZachW04Stang 11-16-2006 11:49 PM
Sounds like its time for new cap and wires. I'm guessing it can have trouble starting when its raining?
AdderMk2 11-16-2006 11:53 PM
my car runs weird when its wet out also.... but its a different kinda weird. My rolling idle is like 1800rpms, and when sitting still, its idles around 1300rpms
but only on wet days, so it cant be a vac leak
GeraldineRyder 11-16-2006 11:58 PM
cap, rotor, plugs, wires, and coil are new. and about the fender mount cai no, i dont even have a cai yet. but my silencer box is removed. its acting like an injector is stuck open or something cause trying to let it idle it wants to stall then trying to baby it aruound it acts like its flooded then you give it hell and it runs fine.
BoostHappy84gt 11-16-2006 11:58 PM
I second PRO50. Spray down your wires with some water and watch the fireworks happen.
BoostHappy84gt 11-17-2006 12:12 AM
a vacuum leak would cause rough idle and bogging out but once you get into the higher rpms it would start running normal again. Check your rubber lines once over and i do mean check them, they can be very deceiving. Also, how close are your plug wires to one another? I know there new but if your spark is strong enough it will jump wires.
blackcrow_75 11-17-2006 02:01 AM
here is an easy way to find a vac leak buy a can of carb cleaner start the car on a clear day and spray it aroung the intake man and vac lines and see if it rev up or dies if it dont rev up or dies no vac leakes than try this pull the cap off spray some wd 40 in the cap wipe it out with a paper towel and let dry and see if that fix the prob could be getting moisture in the cap
