horse power?
horse power?
how much power should this engine get, the car was dyno tuned, i think it's low hp & tq #'s
302 .020 over stock pistons, afr 165 heads, e cam, 1.6 rollers, new bbk ssi intake, 75 mm throttle body,
headers, exhaust, etc... basic bolt ons....
RE: horse power?
with stock cam, BBK intake, AFR 165's and 1.7 RR's my car made 260rwhp
you should be a little higher than that.
you used longer spark plugs with those AFR heads right? stock plugs are not long enough
to extend into combustion chamber.
RE: horse power?
was it on a "Mustang Dyno"? cause they read lower than a Dynojet dyno.
if was Dynojet, yes something is not right, you should be well over 260rwhp and close but not quite 300rwhp.
ORIGINAL: 88coupe50
we were looking around 300 but the car dynoed at 248 hp and 271 tq
i think that something aint right
RE: horse power?
check timming, check fuel pressure, check for vacum leaks. theres alot of stuff to check.. also..what kind of dyno was it? regular dynojet or a mustang dyno? what trans are you using. certain trans take more power to use then others.
RE: horse power?
thanks, i really dont know what type of dyno it was done at panhandle performance in panama city fl
it is my cusins car, i am building my engine haven't really decided on what to do, but i do want to get a vortech supercharger first part of the year. what would you recommend in cam, intake, etc... i have full exhaust i would like to run 12's
RE: horse power?
ORIGINAL: 88coupe50
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
