header question
#22
RE: header question
ORIGINAL: vt89gtvert
And I don't know this one for a fact, but on a stock motor the LT will bogg the motor down.
#23
RE: header question
on a stock or mildly modded motor Longtubes will drop your low end torque. I think the rule for long tubes is 350-400whp or more, maybe someone can correct me? yes they take shorter H pipes, they also drop your ground clearance, run hotter (i think), and are a bigger pain to install and work around.
#24
RE: header question
Long tubes = less restrictive flow of exhaust, should not affect low end if you know what your doing. Plus usually from what I have seen the long tubes run farther away from the block. Which is a plus for temp reasons.
#26
RE: header question
If you are planning to build a stroker or higher rpm engine then the longtubes are the way to go in my opinion. I have them and I don't have any ground clearance issues, they are as easy to work around as shorties, and on my car they made it sound better. I have the BBK ceramic coated ones. If you are going to keep fuel injection I have been told they can cause you to have idle problems because the O2 sensors don't get as warm being placed further down the collector away from the engine. This may not be the case with everybody but my car does have idle issues. I need to get a chip burned to correct this.
#27
RE: header question
ORIGINAL: Evil_F
What do you mean if you know what you are doing? Is there a certain way to install them to make the low end drop go away? It has nothing to do with that... LT's on a stocker will drop the low end; maybe not on a built 302-331-347, etc. I know from experience.
#28
RE: header question
ORIGINAL: AdderMk2
judging by the rust i would definitly say they are mac's... the individual flanges give it away as well
+1 on 92greyGT about what he said with ground clearance issues and the 02. Certain brands are also worst than others. I heard BBK LT's tuck alot better than MAC's. With my MAC LT's and a prochamber my exhaust was VERY low. Sounded good but will never go with MAC exhaust again. Plus their "HTS" coating is the worst.
#30
RE: header question
ORIGINAL: 88BlueGT
ORIGINAL: Evil_F
