what clutch do i need????
I have a 89 AOD going to make it 5 speed,Heres whats i have done to the car-H/C/I from trick flow,24lbs injectors,70mm&Mass air,headers.....i heard i could run the stock clutch? is that true...when i drive i drive hard all the time when i get it out What should i do???
RE: what clutch do i need????
with that setup your gonna want a clutch with more holding power. look into Centerforce Dual Friction clutch kits. they might be a little overkill for your application, but its better to have an overly good clutch than one that will slip.
spec clutches are good, i just bought a stage 1. you could probably use the stage 2-3.
www.americanmuscle.com
i just bought it off of them, got here the next day.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
