What was the lighest year mustang?
#21
RE: What was the lighest year mustang?
ORIGINAL: nitrous_bob
it depends on options and trans first of all, curb weight is not accurate reflection of thre cars weight, that is w/ no fluids whatsover
no mustang EVER weighed under 3000 lbs i can guarantee that.
my '89 5-speed notch w/ 1/4 tank and me in it was 3250 (i weigh about 140) it was w/ skinnies and convo pro's , also was all manual optioned car, ac and smog deleted , the rest full weight, nothing else gutted from it.
aod is about 100-150 lbs more than a 5-speed
and where do you live ? i know where there is a roller notch for sale for $1250
complete ex-texas patrol car, needs motor and trans , could use paint , rustfree
detroit area
detroit area
Your best bet is to find a 4 banger notch and do the 5.0 swap it will be cheaper than a v8 notch.
#22
Yours would be 3110 without you in it. A 4 cylinder engine weights around 100 pounds less than a 302. Im pretty sure under 3000 is more than possible.
detroit area
detroit area
#23
basically what im looking at right now is after its stripped it wont matter, any notchback would weigh the same regardless of options because they would all be removed.
#24
One of my Mustang books here has the following for the 2dr hardtops (non-V8). it only goes up to 91.
64/65-66....2445
67.............2568
68.............2635
69.............2690
70.............2721
71.............2937
72.............2941
73.............2995
74.............2620
75.............2660
76.............2678
77.............2627
78.............2608
79.............2530 coupe/2648 Ghia
80.............2606 coupe
81.............2601 coupe/ 2665 Ghia
82.............2568
83.............2648
84.............2736
85.............2657
86.............2795
87.............2862
88.............2894
89.............2724
90.............2759
91.............2759
Another publications lists 2861 for all 79-93 with a 2.3L.
Im sure none are exact but it should give you an idea. Sort of.
64/65-66....2445
67.............2568
68.............2635
69.............2690
70.............2721
71.............2937
72.............2941
73.............2995
74.............2620
75.............2660
76.............2678
77.............2627
78.............2608
82.............2568
83.............2648
84.............2736
85.............2657
86.............2795
87.............2862
88.............2894
89.............2724
90.............2759
91.............2759
#25
ahhh awesome thats exactly what I was looking for. I just sold a 64.5 mustang to damn.. o well it was a numbers matching 260 car made in the first 3 months of production I wouldn't have made it into a drag car ne way.
#26
the earliest mustangs were indeed the lightest, Im not even sure if the foxes were lighter than the mustang 2s. they werent much heavier than the 1rst gens, and a bit smaller so Id say the mustang 2 would be the best choice if your going to gut it anyway. And especially if your on any sort of budget.
#27
To give you some sort of an idea about how much wieght there is that can come out of a FOX body, my '84 GT hatch has a shipping wieght of 3279#.
Set-up for drag racing with a 5.0/C-4/8.8 combo in it its 2860# with me in the car.
BTW 52% of the wieght is no the rear wheels.
I know where another 40 or so pounds could come out of it. I'm still on the stock front K member and suspension.......
#29
No, because the early Mustang coupe will also be about that heavy but it has some REAL disadvantages.
1) The '64-'70 Stangs are much worse to get big tires (like 10.5w's) onto.
2) They will end up being much more expensive by the time you are racing it.
3) They are not as slick as the FOX body when you think of aerodynamics.
3) they do not have as good of drivers visibilty out of the car as do the later FOX body cars. This fact becomes important if you are going to bracket race at all.....
Diode Dynamics
28
05-26-2022 12:02 PM
01-06-2016 07:03 PM
