rear main seal Q
Old 11-19-2006, 05:17 PM
blackfox6886
blackfox6886's Avatar
Default rear main seal Q
im getting ready to swap out the rear main seal on the stang and was wondering if anyone here has done this and what can i expect and look for ? its a 92 5-spd. thanx
blackfox6886 is offline
Old 11-19-2006, 05:19 PM
frdmstng1986GT
frdmstng1986GT's Avatar
Default RE: rear main seal Q
give me about 4-5 hours to answer you. i am leaving in 10 mins to go and replace front and rear main seals, oil pan gasket, and valve cover gaskets in my car.
frdmstng1986GT is offline
Old 11-19-2006, 05:59 PM
blackfox6886
alright
Boss_Hotrod
Boss_Hotrod's Avatar
They aren't hard. When we replaced ours where drilled 2 holes in each side and threaded 2 sheet metal screws into it. We used the screws to pry the seal out. to put the new one in we just cleaned the surface a little bit and put some oil in the groove then slide the new seal over the crank and then used the old seal to tap the new one in using a hammer.
Boss_Hotrod is offline
Old 11-19-2006, 06:04 PM
mustang93
mustang93's Avatar
its cake!, the hard part is gettin to it all. pull trans, bellhousing, clutch, flywheel, but to pull the actual seal i just screwed 2 sheetmetal screws on each side of the seal, and used those to pull it out. then clean and install the new one. shouldnt take too long if you know how to pull the trans and stuff. good luck man!
mustang93 is offline
Old 11-19-2006, 06:23 PM
silver91gt
silver91gt's Avatar
I use a flathead screwdriver and hammer, tapping the screwdriver so the corner cuts in it, then pry it out.
look for oil above where the seal is, your intake or valve covers could be leaking too
silver91gt is offline
Old 11-19-2006, 09:08 PM
blackfox6886
thanx guys for your help
zsmart
Convertible Tech
02-29-2016 08:33 AM
Demodulates
09-18-2015 11:14 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
09-01-2015 08:16 PM
Quick Reply: rear main seal Q
