New owner with a problem
I am having a problem with my 95 Mustang gt 5.0. After running for a while it wont start back up. this is happening more offten. When it wont start is just crank. I check for fuel, 35 psi. No spark and no injector pulse. I have changed the ignition switch and module. Can you give me other areas to look at
RE: New owner with a problem
Check all of these and see if it helps any.
Hard start/long crank:
plugs
coil
plug wires
TFI
cap/rotor
No start/normal crank:
plugs
ignition switch
TFI
coil
ignition module
cap/rotor
Got any codes?
plugs
coil
plug wires
TFI
cap/rotor
plugs
ignition switch
TFI
coil
ignition module
cap/rotor
Got any codes?
so like, start it 1st time that day, fine... never stalls out... drive to store, go in for 5 min, come back out, wont start... let it sit for a good while, its fine? if so, idk how to fix that, but our 87 silverado did that too.... so im curious as well
