Need some answers to a whistling problem
#21
RE: Need some answers to a whistling problem
ORIGINAL: Ninety5five0
So how'd you rev the engine and have your head there at the same time ???? Very long flexable legs ?
ORIGINAL: mattdel
r u serious Ninety5five0?
#23
ORIGINAL: motorman524
LMAO!!! im still laughin!!
ORIGINAL: mattdel
#24
So I was looking around and found this:
Heres the video:
http://s9.photobucket.com/albums/a10...t=MOV03338.flv
Heres the video:
#27
Hopefully it is a vacuum leak...Try the Carb Cleaner method...spray the carb cleaner near where you hear the sound and if the engine idle speed increases you have found your leak....
For the bad news...I had the same problem with my GT-40 heads and discovered it was actually the valve seals causing the whistling sound....Looked for 3 days for a vacuum leak until I realized it was the heads...they are since long gone...
#28
ORIGINAL: 89GTRed
so did the vac line fix the problem?
ORIGINAL: only90s
#29
ORIGINAL: 86 5.0L
Heres the video:
Heres the video:
that's a thermactor valve right? i'm glad all that crap is gone from mine....
