Bogging out
RE: Bogging out
what do you mean by cutting out? Ultimately i wanna know why my car is slower with 100% throttle than with like 75% throttle. I once accidentally cleaned my TB with Carb cleaner and later learned that theres special cleaners for TB. its a BBK 70mm btw
RE: Bogging out
could be tps, maf, fuel filter, fuel pump, loss of fuel pressure, restriction in air, seconedary ignition, lots of stuff man just gotta look. carb cleaner shouldnt have hurt it this one time but i wouldnt reccomend doin it again.
RE: Bogging out
ORIGINAL: Bumsdeclaf
no i dont think so, i do hear alot of chatter. What about what i did with my TB, i heard if u do that u could damage its finish and cause air starvation to some cylinders
RE: Bogging out
i had a bogging problem and A/F ratio too damned lean, if you have done many modifications you might need to get a wideband 02 sensor and an a/f gauge or go to your local dyno and put in 3 runs and timing and fuel pressure tune it up cheaper than a $3-$400 wideband,, took care of my "bogging"
Seanam
10-04-2015 10:15 AM
Daddys Girls GTs
09-14-2015 08:46 PM
