PS pulley
PS pulley
Hey all, my power steering pump pulley refuses to budge. Any ideas on the best way to take it off? Bout to get a pulley removed kit, but I've used them before, and dont see how it will help here...
RE: PS pulley
YOU NEED A BOLT THAT WILL THRED INTO THE PUMP SHAFT AND A NUT AND WASHER, THREAD THE BOLT INTO THE PUMP SHAFT WITH THE NUT AND WASHERON IT, WHEN THE BOLT IS TIGHT HOLD THE PULLY INPLACE AND TIGHTEN THE NUT UNTIL THE PULLY COMES OFF, WHOOPS THAT HOW YOU PUT IT ON. NEED A PULLER THAT FITS IN THE NOTCH ON THE PULLY WITH A BOLT THRU IT, KINDA LIKE A C-SHAPE. MUST USE AIR GUN.
