Pictures Of 5.0 Engine Bays.
Im in the process of swaping a 86 4 Cylinder to a 5.0. And there is some confusion as to were the water lines go on the pump and return on the firewall heater core. If someone could post up pictures or exsplian were everything goes that would be nice. O Im not goin to run A/C as I dont have the compressor and dont really Want it. Thanks
RE: Pictures Of 5.0 Engine Bays.
Theres an assembly with two metal tubes that run long the inside of the passenger side valve cover on the intake. You need two molded hoses to connect the rear of these tubes to the heater core. The front screws into the front of the intake and the other has a rubber hose that connects to the water pump.
not the best pic depicting it but...
[IMG]local://upfiles/1992/5EC33764F2D34DE08EC0C7AAEE41B6E8.jpg[/IMG]
Well If I dont feel like messing with it right now, can those two holes in the fire wall be plugged? But then what do I do about the Water pump outlets etc, and the one on the elbow that connects to the manifold.?
on the pump. just feed one into the other with a hose.
ORIGINAL: 97BlackStang
waid302
09-14-2015 11:19 AM
Gary Ugarek
08-26-2015 08:41 AM
