Anyone know the difference between these two distributors?
Distro' #1 Mallory 2570401
Distro' #2 Mallory 2555101 Anyone know the difference between these two dizzy's? |
RE: Anyone know the difference between these two distributors?
the one for the 5.0 should have a billit steel dizzy gear made for the roller cam motors.
From my understanding, one is for a 5.0L (EFI), and the other is for a 221-302 (carb).
MAA-2555101 Distributor, Dual Points, Mechanical Advance, Ford, 221-302, Each MAA-2570401 Distributor, Dual Points, Mechanical Advance, Ford, 5.0L, Each I thought i read something a few years ago that some dist. had a softer gear than the other. Not sure which was which tho. |
if u click the "Check to make sure this part fits your application" you will see that on is for 68-80 and the other is 81-95
ORIGINAL: frdmstng1986GT the one for the 5.0 should have a billit steel dizzy gear made for the roller cam motors. |
ORIGINAL: 88GT_5.0Stangman if u click the "Check to make sure this part fits your application" you will see that on is for 68-80 and the other is 81-95 |
ir says iron
