Trickflow cam
RE: Trickflow cam
i wasn't trying to go into detail but yea you'll get valve float and it you don't correct the problem soon i've seen springs break... and that causes all kinds of bad things
ORIGINAL: 5speed GT
you would need to upgrade the springs also, or you will have valve float at higher rpm(I know because I did it)
RE: Trickflow cam
well if i put a cam kit in with a 512 lift spring valves and lifters will i produce some good power....also i have bbk shortys bbk x pipe dynomax bullits turndowns. msd ignition and underdrive pullys.??????? what kind of power am i looking at. 92 gt.....c-4 tranny...and shift kit...
RE: Trickflow cam
ORIGINAL: kenny111
junior04
09-28-2015 10:53 AM
