Breaking loose a stuck O2 sensor...
RE: Breaking loose a stuck O2 sensor...
ORIGINAL: ben5.0
stock h pipes are useless anyways
same with the headers.. i wonder whos brilliant idea it was to pinch them right where they meet the heads so they cant flow.... AWESOME IDEA FORD!
The H pipe isn't stock. It's a BBK Catted H pipe. Adder - the o2 is blocking one of the header bolts and there's not enough room to get around them.
So you think letting the pipe warm up will help?
You probably need a longer extension vig. I remember having trouble getting around the o2 sensor but with a long extension and swivel I was able to get the header bolt.
youll never get that passenger 02 out without having a 3/8 ratchet like the size of 1/4in one and a 02 tool, not the socket.
put a pipe on it and break it off or cut it, if you have to
when i did my exhaust, i had the same problem... i let the frustration get the best of me and used the vice grip and turned the **** outta it... it worked but i dont know what luck you would have... they make a "special" socket for o2 sensors but idk how that would do i never used one... good luck
mcginnt
10-22-2006 11:49 PM
