Did I get the right speedometer gear?
Old 11-22-2006, 10:37 PM
PJB
PJB's Avatar
Default Did I get the right speedometer gear?
Im getting 4.10's put in my car soon (finally found somebody else to do them) and I have this speedometer correction gear:
Jegs part # 890-881004. (cant link to it). www.jegs.com
Its a 23 tooth gear and it says its for 3.73 and 4.10 gears.
My car is a '92 and it has an AOD with 2.73 gears now,
Did I buy the right gear?
PJB is offline
Old 11-22-2006, 10:43 PM
silver91gt
silver91gt's Avatar
Default RE: Did I get the right speedometer gear?
looks like the right one.
silver91gt is offline
Old 11-22-2006, 10:44 PM
PJB
PJB's Avatar
Ok, thanks. I just want to make sure. One of my friends works in a transmission shop and says he can do gears there. He also can install my shift kit.
PJB is offline
Old 11-22-2006, 11:27 PM
AdderMk2
Banned
AdderMk2's Avatar
unfortunatly there is no true "right gear" for the AOD. your speedo will still be off by as much as 5-7mph
AdderMk2 is offline
Old 11-22-2006, 11:45 PM
7upedition
7upedition's Avatar
its as close as your gonna get without swapping the drive gear to a 6 or 7 tooth which is a bitch to do, and a 25 or 27 tooth driven gear wont last...so yea your in good shape, just figure out how far off you are with the particular tires your running...
7upedition is offline
Old 11-22-2006, 11:49 PM
AdderMk2
Banned
AdderMk2's Avatar
cant swap drive gears on an AOD.... its machined into the output shaft
AdderMk2 is offline
Old 11-22-2006, 11:54 PM
PJB
PJB's Avatar
ORIGINAL: 7upedition
Im running stock size 225/55/16 tires.
PJB is offline
Old 11-23-2006, 12:44 AM
nitrous_bob
nitrous_bob's Avatar
ORIGINAL: AdderMk2
thank you, i have argued this b4 til blue in the face.
yes your still gonna be off, and yes you'd have to replace the output shaft to change it
you'll be corrected for 3.55's so figure about 10% off at least.
if your speedo stops working soon, or starts getting noisy, just get another speedo gear, those white 23 tooth gears are from jeeps, and are the wrong pitch for any ford trans. they work for a while though. but will wear out eventually.
nitrous_bob is offline
Old 11-23-2006, 01:08 AM
PJB
PJB's Avatar
Right on the description it says the gear might only last 25k miles. If it lasts that long its fine with me.
PJB is offline
Old 11-23-2006, 01:29 AM
nitrous_bob
ORIGINAL: PJB
yeah it might go longer too, what can you do ? ford only makes a 21 tooth, and for aods, thats only good for 3.27's
so it'll get you closer. besides 2 minutes swap, do it once a year if you have to.
and just for your future reference, i don't know the years, but when you break your aod, if your looking for a new one, some years use a 7 tooth instead of 8 tooth drive gear (i have never seen a 6 tooth for aod , but hear they are out there) anyways, w/ the tranny broke down, swapping out the input shaft is a breeze then you could be right on w/ say a 6t/20t
Quick Reply: Did I get the right speedometer gear?
