Rear End
Rear End
I was up in the junkyard lookin around for some stuff when I came across some tires that were about 3 inches wider than my tires. They were on some decent rims, they were 5 lug though. I grabbed them anyways, and since I have an extra set of rims, I figured Id just put them on, and throw them on the rear. Well, the new tires are a 14 inch rim, and the rims I have are 15. So I decided to do the 5 lug conversion (just the back, until I can get some rims/tires for the front) So I go back up in the yard, and pull two drivers side ranger 7.5 axles (I hope I read right)
I start putting them in tonight, and took the cover off the rear end, and took the spider gear pin out. I cant get to the c clips, because there is this little piece of metal in the spider gears, it is shaped somewhat like an "S" I dont know if this is stock, but it is holding the spider gears from turning (locking the rear end)
I dont know if I was just too tired, or what, but I couldn't get that damn thing out. I was wondering if thats a stock piece, and I need to do something special to get it out, or if its "custom" and I just have to rip it out.
Im kinda dissapointed, because I cant really work on the rig tomorrow, and I gotta go back to college next week, so times running out, and I want to get it rockin pretty soon.
RE: Rear End
ORIGINAL: zombi
The "S" piece is there from the factory. Try pushing the axles inward from the wheel mounting surface. They should move in a little and you'll be able to access the c clips.
Good luck.
Good luck.
RE: Rear End
^+1, to get the S piece out you'l need two pairs of mini needle nose vice grips to clamp each end as it comes out, the best way to do is remove the diff and put it on a bench to sisassemble and acccess the spider gears. But you should have to do this to access the c clips... like said before move the axles arounda bit and they should be accessable
RE: Rear End
the s peice will come out very easily, not al that hard. But dont take it out because they can be ingnorant at times to get back in. Just push the axle in like said above. a magnet (the ones like an antenna) is good to use to get the clips in and out if you have one, if not just push the clips back with a screw driver and they will fall out of the back.
I might be wrong about this but arent the ranger axles 31 splies? do you have a 31 spline carrier.
RE: Rear End
I hope the ranger axles will work...if not im gonna be PISSED
I guess I was just too tired last night, because both my jeep's rear end, and the rear ends from the rangers were a hell of a lot easier to do the c clips. I guess Ill try again tomorrow
