Fuel PSI?? and Idle Problem ???
Ok i have a 88 gt with MAF conversion and gt-40p heads and trick flow stage 1 cam. I also have 24# inj adj reguator and matching c&l I just got my fuel psi gauge and i set it at 38psi key on. Well i was told that the psi should go up when u hit the gas but mine drops down. So i wanna know if it is or isnt supposed to do that?
My second question is that my idle surges like crazy every once in a while. it will go from about 500-1500rpm and dop this for about a min then will go to about 900. Have no idea why it is doing this. Got a new IAC valve and set the tps to about.98 volts. I was told though i might need 2 check the 10 pin connector and clean the prongs but i dunno if this would help. SO anyone have any ideas what could be wrong.
I also have bad news about running at the track. Before i rebuilt the engine and put the MAF conversion 24#inj, adj regulator,ported intake upper/lower,gt-40p heads,Trickflow stage 1 cam,crane 1.7 rockers,pullies and a few other things i ran a 9.1 in the 1/8 mile. It only had headers and flows. I went last week with all the new mods listed above and ran the same exact time??????? I am really pissed i have no idea why this is. Maybe it is fuel related but i have the timing at 14 deg. But when i would launch the car kinda bogged then went back up in the rpms. So i really dont know what would cause me the run this slow. I know im not that great a stick but i still should have gained some speed prior to adding all those parts and a rebuild. BTW has stock gears and 17in rims. before had 15's so i dont know if that makes a huge difference. anyways sry for the length. O my 60fter was 2.1 sux ***. before it was a 2.2. NO Traction. Well any ideas on the cause or how to fix my problems? thnx Craig
RE: Fuel PSI?? and Idle Problem ???
No one has had any of these problems before???? Man this sux i need to get this fixed and dont have the money yet to take it somewhere any ideas at all plz. thx
well i know with stock gears and a stage 1 cam u r gonna run ****y with that cam u need 3.73's, stock gears suck that is why it bouggs down also the 17's dont help at all, especially if u got crappy tires. as for the fuel pressure prob id expalain it but u might get confused so just go here
>>>>>>>> http://minimopar.knizefamily.net/fue...l.........this should help......the surges could be a fuel related problem.
ORIGINAL: 88GT_5.0Stangman
Plus he doesn't say what the difference in the weather, if any, was between the before and after passes at the strip. weather has a lot to do with how a car performs.
Anyway, that is a good article on that website!
musnicki
09-23-2015 07:11 AM
YoungStangsMan
09-05-2015 07:01 PM
