speedometer needle bouncing?
RE: speedometer needle bouncing?
ORIGINAL: 855.0sean
its your gear inside the tranny it connects to your speedo cable i just replaced mine. its probably stripped in the inside of it.
you have to order it from a ford dealership.
its easy to replace3 id recomend lifting your car though so much easier!
i replaced my cable and the little plastic gear that goes on that cable into the tranny and it still happens. only 2 things i can still guess are bad, either the plastic ring gear inside the tranny or whatever is inside the instrument panel
ORIGINAL: nseoi
ORIGINAL: onesickstang01
wait..you own a mustang and you drive under 30? haha i agree with ltnone its just a mustang thing, kinad like the ashtray door and also the damn turn signal flashers
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
79, 92, 94, bouncing, bouncingnoisy, bouncy, fix, ford, fox, jumping, mustang, needle, speedo, speedometer, speedometerbounces
