What does it take to make the front end come up.
RE: What does it take to make the front end come up.
what kind of susp. tho guys? I had southside lowers and she bit like crazy. what other stuff should you have? 90/10s and 50/50s? could you use 4 cyl springs in the back instead of the v8 springs or should you get a set of drag springs? do you have to have upper control arms? I am curious about this subject too.
2 yards of broken asphault in the back and launch at 3k on a backwards roll , i got almost 1 foot off the ground that way
seriously, 4.10's on a full slick, no weight dumped off, 5500 launch will yank 6"
So how do u launch at 5500 I mean Isnt that close to redline... Or is that the goal to launch close to redline and hook so when the rpms fall itll be in a fair power range?
I desided to ask this question due to the ALL the pinks episodes I watched yesterday... I saw the whole days worth.. There was a blue mustang comeing way up and leaving FAST.
you want to launch as high as you "safely" can while still hooking
stock axles will (sooner or later) break on 5k launches
i like cheaters for the fact that you usually break loose b4 you will break an axle.
but yes, you got it
but yes, you got it
Im debateing on a Built t5/or tko vs a built Auto.. It will be for street mainly with maybe 20% strip. Can Manuals still hang with this kind of abuse.. Assumeing Built.
Now someone list a good suspension setup that will HOOK on a budget?
