can i rebuild my own engine????
do i have to pay and take my 351w to an engine builder in order to rebuild it? I work in an auto part store, have books/manuals and i can borrow any special tools to build the engine. I did take the engine apart myself and left the bare block.
But, of course, i will leave all the machine work to the pros. I need your advice. Im going to swap the 5.0 for a 5.8. But my block isn't a roller block. Does that matter. It's basically a 351w from a '72 Ford Torino. I know that roller blocks can tolerate more aggressive cams.
Can anyone clear out the pros and cons if any between the two blocks? but back to the questions.
1. can I rebuild myself?
2. can i reach my goal of 300rwhp with a non roller block?
RE: can i rebuild my own engine????
IMO anyone with normal mechanical aptitude and the ability to interpret the manual can rebuild their own engine. Of course machince work requires special mahinery, tools and skills but you already realize that. The only way to know for sure is give it a try. I did my first one @ 16, I would just reccomend that you take it slow, read and re-read each step before you actually do it.
Yes you can get 300rwhp with a non-roller block with the right match of components. Do alot of research and know exactly what you want from your vehicle when making those decisions.
Luck
Luck
I agree i did my first one in high school shop class. Its not that hard just follow directions and check your clearances at least twice. Also if you can start the engine before you put it in your car DO. Nothing sucks worse than putting it back only to find somethings wrong. Just take your time, if you get pissed walk away for a minute Good Luck
i was thinking of going with a stock bottom end. Nothing really fancy, ( which is a word i use to replace expensive). just the stock crank if it can still be used, some forged pistons, a borderline street cam kit, some AFR heads, a weiand stealth lower intake, and maybe a holley street avenger 650-750cfm carb.
Do these parts sound ok for a good 300rwhp? any advice on other parts i can use?
How is my gas mileage gonna be? maybe 18mpg? yeah right......
Thanks for every piece of advice.....
youll need a cherry picker, a truck floor jack and two jack stands, be prepared to break exhaust studs and have the emission piping bolts snap in the head, on the rear, etc etc,.
but we can help you
and out of all normal running 302's , I have yet to find one with worn bearings or rings , even with high mileage. Id put a top end kit on her and save the rebuild for later.
For 300rwhp a stock bottom end will prolly be ok, but make sure you use forged pistons. Also with the H/C/I you'll probably exceed your rwhp goal. But as you choose your components you need to think about what you want out of your car. Where do you want to make the most power? Top end or down lower, the 351 is gonna have plenty more torque than the 302 anyway. There will also be alot of odds and ends. A 351w conversion isn't just dropping in a 351w engine. Check out this to start you off on your research.
https://mustangforums.com/m_1121694/tm.htm
Keep in mind you are planning a carb so some things will be different.
my only goal in mind is street racing. I want to be able to take on any street car. even with my 92 5-speed gt i don't back down from anybody and it only has 3.73's ac and smog delete. explorer intakes.
but anyway, i just want to eat ricers alive and leave camaros thinkin WTF HAPPENED........
