How much is a good price to ask for my Mustang
The car needs a paintjob but the body is straight, only rust is survace at the rear wing area... The wheels/tires/suspension is on the car.... whats a fair price to ask? Just curious, thinking about buying something newer...
1993 Mustang GT 5.0 w/ AOD
MODIFICATIONS LIST - Last updated 10/18/06
Last weight: 3220
-- Exterior/Looks
LX Taillights
-- Interior & Audio
Alpine CDA-9856
-- Engine/Other
Removed Airbox silencer
K&N stock replacement filter
FRPP A/C system delete
Removed Smog
"Short" Belt
-- Ignition/Electrical
PA Performance - 130amp alt.
Timing advanced to 14*
FRPP Plug Wires
MSD Cap/Rotor
MSD TFI Coil
Autolite #25 plugs
-- Transmission
Performance Automatic - Super Streeter AOD
Edge Racing Converters - custom 2600 stall lockup converter
FRPP flexplate
B&M Trans cooler
-- Cooling system
Jegs Aluminum Radiator & cap
Proform electric fan w/ adj. thermostat
FRPP Hose kit
Milodon 180* Thermostat
Jegs Aluminum water pump...
-- Exhaust
BBK Ceramic headers
BBK Off-road Catless H-Pipe
-- Rear Axle
FRPP 3.73 gears
Trick Flow rear support Girdle
Royal Purple + FRPP Friction Mod.
-- Suspension
FRPP Sport spring kit
KYB GR-2 Front & Rear shocks
KYB Gas-A-Just "Quad" Shocks
Energy Suspension F&R Upper/Lower Spring isolators
Maximum Motorsports HD Adj. rear lower control arms
FRPP HD upper control arms
-- Bought & Waiting for install
Cervinis 93 Cobra body kit..
Prothane eurethane motor mounts
StopTech stainless braided lines
SN95 Balljoints
Prothane front control arm bushings
SN95 front spindles/rotors/hubs/calipers
Moser 5-lug axles
10th Anniversary Cobra Wheels
BFG G-Force Sport F-245/45/17 & R-275/40/17
Last weight: 3220
-- Exterior/Looks
LX Taillights
-- Interior & Audio
Alpine CDA-9856
-- Engine/Other
Removed Smog
"Short" Belt
FRPP Plug Wires
MSD Cap/Rotor
MSD TFI Coil
Autolite #25 plugs
-- Transmission
FRPP flexplate
B&M Trans cooler
-- Cooling system
FRPP Hose kit
-- Exhaust
BBK Ceramic headers
-- Rear Axle
FRPP 3.73 gears
-- Suspension
SN95 Balljoints
Moser 5-lug axles
RE: How much is a good price to ask for my Mustang
If it's as straight and rust free as you say, and assuming it runs/drives great (you didn't mention it did) depending on the mileage and where you live I would say probably between $3500-$4500.
Diode Dynamics
28
05-26-2022 12:02 PM
08-14-2015 12:27 AM
