Cam question
Cam question
Just bought an 89 GT with about 140k miles on it and have Trick Flow upper and lower intakes, Twisted Wedge Heads, on the way. Car has cold air intake, bbk headers, flowmaster, and few other minor adds. Question is what cam should I snag for this sucker. Don't want anything wild because the guts of this motor is still stock. Just something that will give me a few extra horses and new sound to it. Thanks for all the help gang!
RE: Cam question
three words
BUY MATCHING COMPONENTS
Trickflow Stage One Cam and 1.6 Rollers
Trick Flow Twisted Wedge 5.0L EFI Engine Kits
Top-end kits that pack a serious horsepower punch!
Why mix and match top-end components, when these Trick Flow Twisted Wedge 5.0L EFI engine kits can give you dyno-proven power without the guesswork? Built around Trick Flow's Twisted Wedge cylinder heads, these kits include a specially matched hydraulic roller cam that enhances the broad power and torque curves of the Twisted Wedge design. These cams feature a 221°/225° duration at .050, .499/.510 in., with a 1.6 rocker ratio, and a 112° lobe separation. Other components include roller rockers, a gasket kit, timing chain, pushrods, and silver valve covers, all perfectly matched for optimum power!
RE: Cam question
o h yeah !!!! [8D]
hell yeah, done quite a few that way, just take your time, it will take you a day or two to do the whole thing. but you cant stop wiping the grins off your face.
Hardest part is removing the grime and corrosion from the water pump and plate without damaging it, BUT TAKE YOUR TIME WITH THAT.
and remeber some of the studs/bolts go through water passages, so rtv those a little, in fact you could do em all that way if in doubt, but youll know when you take em out
RE: Cam question
Well if I get:
Then should I just rebuild the sucker? And what else would I really need to complete the rebuild?
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
