4v 5.0?
RE: 4v 5.0?
ORIGINAL: 82FBGT50
Actually it doesnt mean 4 valve, it has something to do with the factory carb. 2v means 2 venturis (SP) or 2 bbl and the 4V means 4 venturis(SP) or a 4 bbl carb.
RE: 4v 5.0?
Which relates to the number of throttle "valves" there are, a 2 bbl has 2 valves in the carb, a 4 bbl has 4 air valves. It can be confusing though because of the nomenclature used with the Modular engines the older DOHC engines have 4 valves per cylinder and the SOHC engines have 2 valves per cylinder. People have shortened this to 2v & 4v. The newer Mustangs have 3 valves per cylinder and have likewise been shortened to 3v motors. The older engines refer to the # of air valves in the carb.
Hope I didn't confuse you....
Then you have the new 5.0L Cammer engine which is a modular 4.6L that has been stroked and has 4v heads which I think is where people get confused (5.0L 4v).....yea!
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
