5.0 Heads HP & Torque Testing Results from MM&FF mag
These are the results that Muscle Mustang and Fast Fords measured in their comparison test last year on street performance heads. The HP and torque values were all measured on a dyno on the same engine slightly modified from stock with 306 ci and a Comp Cams XE264HR cam with.512" lift on a 114 degree lobe separation. duration was 212/218 at .050 lift. They noted that the best flowing heads didn't necessarily make the best HP and torque either. Check out the flows on top and the HP & torque below and you'll see what they found out. Good information to help you decide which heads are for you!
This came from the September 2003 issue of MM&FF magazine if you want to read the whole article and can find this copy of the mag. Enjoy!
[IMG]local://upfiles/5542/2C90172E1F8D45B2A7D337DC9F63F1D8.jpg[/IMG]
[IMG]local://upfiles/5542/7E2AD7A45B0D410FA007371DABCEA53C.jpg[/IMG]
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
