o/r pipes with emissions
I live in Ga where we have emissions, can I run an off road h or x pipe ona fox, and what is the difference with an aftermarket h or x pipe, more flow. Is there something that has to be done to make the o/r pipe legal to use on a vehicle with emissions?
RE: o/r pipes with emissions
you can run with offroad h or x but when its time for inspection and emission then you need to put them on to make the exhaust legal
ok i think there needs to be a sticky about this....
In the United States of America: it is ILLEGAL(FELONY), in EVERY state, to use an off-road exhaust on PUBLIC roads. Catalytic converters have been installed from the FACTORY since 1973 on all American made vehicles. Any vehicle made after 1973 must have a Catalyst sticker under the hood to pass inspection, as well they must also retain ALL stock catalytic converters. Alteration/removal of the cats is subject of a fine UP TO $10,000 PER CAT. [:o] |
damn.....thats a law that isnt abided ::knocks on wood:: hope they dont take action.
+1
but you may want to read this guys thread before making any decisions to do that [:@] https://mustangforums.com/m_2320012/tm.htm |
put what back on, the original exhaust? does the o/r pick basically delete the cats all together?
correct. O/R hpipes or xpipes are just replacement mid pipes without the cats.
His post is the exact reason I asked that question, thanks for the info btw.
If you have to pass emissions forget about an off road h-pipe. You can get a h/x pipe with high flow cats though
Are the o/r pipes with hi flow cats pricey, and are there certain brands I should look out for.
