I want ODB II
I want ODB II
How do i get odb 2 in my 94? it already has the plug in for it, and has power going to the plug. i had it in my 95 v6, so why didnt Ford pull their heads out of their asses and put it on the gt's as well?
RE: I want ODB II
[sm=funnypostabove.gif] and i second that, i did at first then i looked into piggy back systems and megasquirt (thanks adder) got one on the way now i just need a laptop
RE: I want ODB II
which MS did you get... i got the v3 MSII
and i just found otu that you can use a MAF with the MS to get even BETTER tuning capability than running JUST a MAP, or just a MAP... you can use a MAF/MAP blend... w00t
RE: I want ODB II
i'm pretty sure thats the same one i got i talked to some guy on the phone and when with his suggestion... told him i wanted to run a maf and told him what was going into the car, hopefully i get it together ok... is there anything other than the MS tunning cable and the adaptor to plug it in that i'll need?
RE: I want ODB II
What are you guys talking about. i figured odb2 was better, i have heard of the SCT chips had one of their products in my v6. and of the tweecer. what other tuner are there for non obd2 cars?
RE: I want ODB II
anderson PMS, Megasquirt there are a few other can't think of them right now tho... happy reading https://mustangforums.com/m_2303951/tm.htm
Rwederfoort
05-29-2012 10:02 AM
