c&l 76mm mass air help!!!!!!!
#41
RE: c&l 76mm mass air help!!!!!!!
ORIGINAL: 89GTRed
ROFL...dunno why but that just cracked me up.
Hey highway21 can you post a pick of the C&L maf and yellow sample tube? I have the c&l maf and always heard about the tube but I never saw how it could be changed... Mine hasnt had any probs and was supposed to be for 19lbs but I still dont get the sample tube part. Seems like on mine if you wanted to change the size of the tube where the sensor pops out into the maf that you would have to get a whole new maf...Since the tube that the sensor pops out in is molded metal the same as the rest of the maf.
original:crazyhorse
thanks pro & i am very relaxed.
#42
ORIGINAL: 1FUN5.0
way to come in guns a blazin' with the wrong info! in your first post!
ORIGINAL: lx50x
the tube has nothing to do with it it's the sensor that changes for the injector size, the sensor might be bad try putting the stock sensor in the c&l tube, you also might trying to adjust the timing
#44
It may take some time for the computer to adapt to this change. 50 miles should be plenty.
Double check the diameter of the sample tube. C&L has been known to provided mis colored sample tubes.
I have diameter and color charts on my site, somewhere.
Clocking has been known to help, as the C&L tube is pretty sensitive to inconsitent airflow across the diameter of the MAF.
Let us know how it works out,
jason
jason
