Fascinating substance in coolant resovoir.
RE: Fascinating substance in coolant resovoir.
It's delicious. Problem is it makes it hard for you to fall asleep for a few days. Also, you lose a lot of blood, so you may want to use the toilet with the lights off so as not to scare yourself.
ORIGINAL: vt89gtvert
^^^ do you find the summer heat doesn't bother you as much too, or is that just me????
ORIGINAL: HACKGT350
haha i was thinking the same thing...drain your oil and see if antifreeze comes out first
ORIGINAL: SteveSkal
Ummmm you may want to check for a blown head gasket my friend LOL.
Well, I'm tearing the whole thing apart anyway. Gaskets will have their turn soon enough.
when water touches metal whether it's aluminum or iron,a little chemical reaction takes place. it's called galvanic corrosion. the corrosion doesn't mix with the anti-freeze, therefore it settles to the bottom of the radiator. just leave the petcock open and flush it real good
