93 LX has a dead miss
Newbie needing help. I have a 93LX 5.0. Bottom end is stock other than a Comp cam. I have Roush 200 cast heads and a cobra intake. BBK CAI, BBK 70mm TB, Pro M 75mm. meter. My gas pedal stuck and hit the rev limiter. Now I have a dead miss from #4 cyl
I have checked the plug, wires and distributor. All seem to be working. What are your thoughts on my problem. No unusual noise coming from the valve cover but I havent pulled it yet.
RE: 93 LX has a dead miss
if a compression test shows loss ofcompression you may have valve spring issues. you also may not find any loss of compression which could mean a broken spring. listen to see if you hear any unusual noises coming from that set of springs. if needed remove the valve cover for further analysis. a broken spring is easy to fix
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
