Bedliner in the engine bay..would it work?
RE: Bedliner in the engine bay..would it work?
I baught the sh*t thats in a can. Its pretty much the same thing though. Its Tex Coat Chip Gaurd. Did my whole interior with it and it came out pretty well.
It really depends on what he is looking for. If he wants something that is heat,chemical,fuel, etc. resist then he should go with Line-X.
I'm actually going to tear up my carpet and have it sprayed along with my trunk. Later on I will probably get the engine bay done.
Line-X is also good at suppressing sound.
a plus about that stuff is, you can get it in the same color as your paint job, a downer about that stuff, water can get trapped inbetween it and the metal causing rust.
that Line-X stuff is pretty badass, very strong stuff. Don't think it will look too good in an engine bay though. Just remember for you guys that are thinking of using it....once it is on, that is it, it is on. YOu have to sand all the way down to the bare metal if you can get through it first.
My father in law has an old Jeep and he had Rhino liner sprayed on it because it was cheaper than a paint job. It is some pretty tough stuff that can take a beating. I definately wouldn't hide some wires under it though.
