Intake (Which one do I have?)
RE: Intake (Which one do I have?)
ORIGINAL: frdmstng1986GT
they are right under your valve covers.
I figured that's waht I needed to do. I don't give myself enough credit - :P
Swirl
If you look carefully, you should be able to see them thru/around your accessories. The alternator and bracket attach to the passenger side head, so look around there and see what it says. Also, aluminum heads will look very different than the cast iron your block is made from, so compare the 2 if you can.
ORIGINAL: gspfunk
Swirl
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
