Different way to put it on?
#22
RE: Different way to put it on?
ORIGINAL: hatch
CAN YOU SEE THE BOLTS THAT HOLD THE MIRROR FROM THE OTHER SIDE IF YES PULL THEM OFF
Its not a washer actually, its a bolt but its really thin!
#24
IF YOU'RE NEW MIRRORS COME WITH NEW BOLTS F--K THE OLD ONES JUST BECAREFUL YOU SHOULD BE ABLE TO GET THEM OFF THE NUTS ON THE INSIDE SHOULD LOOSEN UP IS THE MIRROR BROKEN OFF OR STILL THERE I SORDOF DONT KNOW
#25
the mirror was broken off, i got the bolts off, and the nuts fell out i got all 3, but there is gonna be no way to get a wrench inside to tighten the nuts up
#29
ORIGINAL: Black95MustangGT
if i go any bigger it says the file is to large.
#30
I did it!
There was a black nut hard as hell to see! Really deep inside the speaker, after that took me 3 minutes to finish the rest haha. thanks everybody!
