Different way to put it on?
I just got my side mirror in the mail, it's the passenger one.
The haynes book says i have to take the door panel off, i was told just remove the speaker? which is it!
RE: Different way to put it on?
If they are power mirrors you might have to pop the panel off so you can unclip it from the harness and plug in the new one. I never took off a door panel on a Sn-95 but I couldnt image its that much harder than a 5.0. I could have both door panels off my car in 10 mintues easy.
yeah it is easy taking the panels off ive done it before to fix my window but i didnt work =\
i have trouble putting them back on though, seriously.
I don't know if you been answered but you need to lower the window and pull up on the panel it sord of hooks in the door actually thats exactlly what it does be careful with the handle or you'll brake it to put it back in line up the holes on the door to the hooks on the panel easier said than done but its possible go over all of the hooks to make sure theyr lined up and push down on the panel don't forget the door pin some of the fabric might stick out at the top along the window use a flat head screw driver and push it down becareful not to rip it hope this helps good luck
ORIGINAL: 88BlueGT
why are you having trouble putting it back on? getting the plugs lined up or something?
