2 1/2 in vs 3 in exhaust?
RE: 2 1/2 in vs 3 in exhaust?
For best performance exhaust are supposed to flow around 250ft/sec. This book makes it seem weird. To me what im at should be like dual 1.5. I think i'm gonna have to say f*** this book I'm sticking with my 2.5.
http://www.magnaflow.com/07techtips/faq/question10.htm
[IMG]local://upfiles/1583/9E5AD88E542B49BEB4EA649333499DBB.jpg[/IMG]
ORIGINAL: vfast
NO what happens is the exhaust can pull some of the intake valve charge during that split sec the valve hang open together making a power loss...so just put on some 3" tail pipes it looks impressive
Pipe Sizing:
We've seen quiet a few "experienced" racers tell people that a bigger exhaust is a better exhaust. Hahaha… NOT.
As discussed earlier, exhaust gas is hot. And we'd like to keep it hot throughout the exhaust system. Why? The answer is simple. Cold air is dense air, and dense air is heavy air. We don't want our engine to be pushing a heavy mass of exhaust gas out of the tailpipe. An extremely large exhaust pipe will cause a slow exhaust flow, which will in turn give the gas plenty of time to cool off en route. Overlarge piping will also allow our exhaust pulses to achieve a higher level of entropy, which will take all of our header tuning and throw it out the window, as pulses will not have the same tendency to line up as they would in a smaller pipe. Coating the entire exhaust system with an insulative material, such as header wrap or a ceramic thermal barrier coating reduces this effect somewhat, but unless you have lots of cash burning a hole in your pocket, is probably not worth the expense on a street driven car.
your seem confuse some...header wraps, coatings keep heat in the pipe to speed the gases up, yes going to a too large pipes hurts hp anything bigger than 2.5 duals it a waste of $$ and will hurt performance...going to the 3" tail pipes will not hurt hp nor help as the gases have cooled some. header length has alot to do with hp increases and rpm ranges as they need to be tuned to the engine when high hp's are present
ORIGINAL: vfast
10-01-2015 05:13 PM
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
