Whats it going to take?
ON A MUSTANG???!!!!.....dude 14s is probably just a matter of learning to launch and taking some weight off the car, jacks, 1/2 tank, tools, rear seat ....that should be enough....if you're a lil over weight and took a few pounds off of there too that would help....<IMG src=smileys/smiley4.gif border="0"></P>
Learn to react and hook.....big key!</P>
On a healthy stang 14's should be easy to reach if you can drive. But i'v seen MANY MANY mustangs at the track run 15's when they think they should be running high 13's. Some cars come from Ford ready to run and some need sent back. Figuring the worse case scenario and that your car runs low 15's. The gears should net you half an second and the juice a full second dropping you in the high 13's. Again this is worst case scenario. Which should always be figured so that you can minimize the dissapointment when you don't run nearly what you think you should.<u>healthy</u>
