I Can't Take It Anymore
Someone has got to help me...the squeeking is so loud in the front end of my car when im driving really slow that its louder than my exaust...what do i need to do to fix this...it squeeks when the car moves up and down and when i turn the steering wheel both ways.
RE: I Can't Take It Anymore
Outer tie rod ends very commonly make a loud squeaking noise on SN95 cars when cornering, going over bumps or even just turning the steering wheel. The originals are not greasable and when they dry out they're noisier than hell. I've experienced it personally and know three other people that have had it happen to them as well. Outer tie rod ends are quite inexpensive, but you should have an alignment done afterwards.
To verify that this is the problem, get a buddy to help. Reach behind the front tire and put your hand on the bottom of the outer tie rod. Have the other person turn the steering wheel or bounce the front of the car. Whatever it takes to make the noise. You should very distinctly feel the noise in the tie rod end.
Very common problem with all of Henrys late model vehicles! My 98' Ranger did it, my 97' Thunderbird did it and my 04' Mach 1 does it. I just spray all my front end bushings with some light-weight oil.
stangin1996gt
09-21-2015 11:01 AM
MtnMustang
08-16-2015 08:07 PM
