400 hp
#41
RE: 400 hp
ORIGINAL: ih8chevy
what was ur time cause this guy said he was a mid 11 sec car and i thought that was a little fsat, i was think low 12's nut yea what was ur time
#42
RE: 400 hp
My buddy took a lightning block and stoked it to a 408, with a stage 2 trick flow and 1.7's,ported wedge heads and spyder intake he puts down.. 445rwhp and 470rwtq. The whole car is for sale for 6500. He cracked his oil pan, bought the car complete and doesnt want to pull the motor to change out the pan. The money he has in exhaust, brakes, and suspension is worth 6500.
#43
RE: 400 hp
OK, back about 8-9 years ago a friend of mine and I built a lightwieght '68 Mustang and raced it..
We used the following.......
'69 351W block and C-9 heads, heads had 1.94 valves and I 'ported thme with-out a flow bench, just blended everything togather and carefully matched both intake/exhaust ports.
Small mechanical cam (flat tappet) solid. Think it was about 286in and 288ex with about 540 lift both sides.
10:0 flat top hyper type pistons, zero deck.
moly rings.
Single plane intake (eddy I think).
&50 vac secondary carb with light springs.
C-4, manual valve body
9" with 4.30
29X9" Goodyear slicks. Very used off stock eliminator car.
The '68 was only about 2900#
BOSS 429 scoop.
We ran as good as 11.60/118 up here in the Arizona desert.
Most of you guy's live near sea level so your stuff should be quicker/faster
Remember, '68 Mustangs are huge compared to FOX body cars and knowing what I know now, car could have been at least .40 quicker.
BTY, whole car was built for less than $4000 but that was back then and we had both the car and the engine/heads/C-4 to start with.......
moly rings.
9" with 4.30
BOSS 429 scoop.
Matt's 95 Stang
10-05-2015 07:16 AM
