windshild wipers
RE: windshild wipers
ORIGINAL: 92Mustanglx
Ok my windshild wipers wount shut off.. the thing that controls their speed is at zero and there still moving..
Get this though the stop with the parking brake on or with the key backwards.
but if the car is running or in the on spot only the parking brake turns them off.
im so confused please help.
Please help
ORIGINAL: 88blackgt
you're sure you got the right connector? there are 3 that go into the turn signal module, and only 1 is for the wipers
o i thought you tried what i said to do. take the trim off your steering wheel, unscrew the entire turn signal assembly, and take the electrical connections off the back, not sure which is which but you can do some trial and error. there shoudl be 3 if i remember right
