installed trick flow intake, idling rough
I just got done installing a trick flow street intake on my 87 mustang 5.0. I got it to idle but it sounds really rough and when i give it gas it dies when i let go of the pedal. It seems to be runing lean. Any ideas of what i need to do?
Thanks,
Ben
Thanks,
Ben
RE: installed trick flow intake, idling rough
checked for vacuum leaks didn't find anything, messed with the timming, it didn't change much. Next i'm going to mess with the tps. Also i don't have a MAS. would i need one with this intake?
MAS is the sensor and MAF is the tube/assembly.
The speed desitiy should be able to handle the intake swap. Did you hook the MAP back up? PCV? I would bet you have a vacume leak. Do you have the vacume line hooked back up to the FPR? Something simple I bet.
ORIGINAL: mislead
yes thats what i mean't. Also it is shooting out alot of white smoke.
