a few questions..need a carb junky
#41
RE: a few questions
i replaced that...wronp style of pop compared to a bad power valve
ORIGINAL: Evil_F
Like someone else has mentioned. You may have blown your power valve in it.
#42
RE: a few questions
A no choke will not cause popping unless it's cold....and that's not a given
88 so you closed the choke and it runs? tells me you have a vacuum leak if you close the choke and the engine is warm it should just quit running for being choked out
ORIGINAL: FiveLiterRiceEater
a choke will cause a miss or a pop through the carb? i never knew that.. i've run a quadrajet for years with no choke and its always been fine. how does this happen?
#46
RE: a few questions
this carb is junk...bolts shoved into lines,and the egr prob don't work as well...
i'm placing an order for a 600-650 4bbl...eddy dual plane intake 262/276 488/496 cam double roller chain
just not sure on what dizzy to pick from...and as soon as i put this power valve into this crappy 2bbl...it popped right off the bat.
#47
RE: a few questions
well i took that wire off...no change but i did bump the timing a little...
ORIGINAL: 2 kwik
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
