M90 Q
RE: M90 Q
ORIGINAL: Mowin8603
hmm never heard of this, but i actually just sold my M90 powered GTP.
arent supercoupes centrifical supercharged??
aaand zzperformance.com is a big w-body store that carries M90's but dont think they have anything for the mustang. this would be very interesteding if something like this would work.
RE: M90 Q
ORIGINAL: 94gtcoupe
who makes the m90 can't think of it right now??? any way if you contact them they should be able to tell you if one is made or not and if so who makes/sells them....
Also, i forgot. i toyed around with this idea cause i had a crappy supercoupe that had a blown head gasket and i also at the time had my 92 t-bird sport with the 5.0 in it and i looked everywhere for a intake for it... NOBODY makes one. it has to be custom made.. the price quote i got was $2500-3000 just for the intake.. not to mention the snout on the intake has to be extended (another $600 or so). so yeah, it would be much cheaper to buy a paxton novi 1000 or something and have a better setup that will mostlikely make more boost. the eatons max out around 15psi of boost with a ported case and then you are spinning it.. alot and you better have a good ic setup cause that thing will be producing alot of heat spinning that much.
