Front swaybar question
#21
RE: Front swaybar question
Ok so i talked to him he said without a front sway bar whenever i take a turn since my front axle isn't one piece the two pieces will bend in different directions and the front axle will brake
#22
Not true. Ask him why drag racers don't ever use a front sway...... All the sway does is help transfer weight in corners to equalize body roll. I run mine, but I want to handle well.
I went w/ Energy Suspension end-links and sway bar bushings from Summit. They were under $30 for all, IIRC.
#23
He told me i could take if off for the dragraces but i'm pretty sure i'm not going to do much street racing... especially around curves. and i don't wanna jack with taking off and on everytime I go to the drags.
#25
yeah that's no problem and I like the weight reduction it gives me....question! I am putting a 4340 eagle 347 stroker kit in my engine with a ford racing hydrualic roller cam e303 and hydrualic roller lifter the other stuff is stock. what the likely hood of popping the tires just a little bit. if not what else to I need.
#28
ORIGINAL: Bwebb Stang
Really, w/ a 347, you should be able to break 'em loose w/ either.
#29
I'm talking about popping the front tires up a little bit. yeah i dont' need a really good handling car plus i was gonna put a top strut bar on it and some subframe connectors so i personnaly think i'll be fine.
